Start-up current is far less than running current
Can you post a drain current and voltage waveform. It may be that either the output diode recovery time is too slow, the clamp voltage is too low or the transformer capacitance is too high.
These waveforms will help identify. Take the waveforms at 4 amps into 6 ohms.
Cheers
PI-Chekov
Thank you for all your suggestions but the problem was simple as I thought it would be. I used 1200 uF X 3 capacitors for the output as the design software suggested. I also used a secondary filter with an inductor and another 1200 uF capacitor. It was this extra load of 1200 uF that was causing the start-up issue. I removed one of the 3 primary 1200's and left the secondary filter. Now it starts up with a 6 Amp resistive load with no problem.
Since my project uses multiple external devices each with their own big capacitors, I will need to use a circuit to ramp up the current flowing out of the power supply so as not to overload it during start-up.
Bryan Mills
Senior design Engineer
Fireye, Inc.
Derry, NH 03038
