Ringing on output
I've designed a power supply based on the TOP245. I've a problem with some ringing on the output. I first thought that it was the capacitance of the output diode and the leakage inductance of the transformer. I tried to add a snubber, but adding a capacitor didn't change the ringing frequency, so I'm in doubt whether it actually is the output diode.
Where else could the ringing come from? It occurs just before the voltage over the drain of the TOP245 reaches the reflected output voltage (in the downgoing slope of the initial voltage spike). The drain voltage itself shows no sign of ringing though.
Please find attached a schematic of the current design.
Thanks in advance,
Remco Poelstra
I believe that it is the values for the post filter you have chosen are causing the problem. By choosing 10uH inductor and 1000uF capacitor for the LC filter the cut off frequency of the LC filter is very low. This can cause oscillations because you are taking feedback from before the LC filter, which should be a stable system, then summing that with the LC filter which is a stable system. The sum of two stable systems does not necessarily equal a stable system.
Try shorting out the inductor and then measuring the output voltage. If you do not see the ringing with the inductor shorted out, try choosing a smaller value inductor and smaller value of capacitor C4.
Also if you're using a linear regulator an LC filter shouldn't be necessary anyway.
If you use a TL431 voltage reference with 1% tolerance feedback resistors you can get as good as 5% regulation. Perhaps this could also eliminate the need for the linear regulator, improving efficiency, reducing cost and simplifying the circuit.
What is your efficiency and output voltage tolerance specification?
Good luck!
-PI-Wesley
