Remote ON/OFF in TopSwitch
Posted by: ohnate
Depending on the configuration, TopSwitch HX comes with voltage monitor pin (V) or multi-function pin (M) that can be used as a remote ON/OFF switch. But it appears that when it is "off", it consumes at least 160mW. The power consumption seems fairly high - comparable to power consumption in standby mode for devices that operate in burst mode or skip cycle mode, and several times more then standby power with devices that use auxiliary winding. I am assuming that it is due in large part due to the use of internal power (current) source directly from the HV (D) line.
Is there a way to decrease the standby power using TopSwitch HX? The best answer I can hope for is that my understanding of the data sheet is wrong and the power consumption is much lower!
Please ignore - just a test post
hello spock,pls let us knw the way to reduce the standby power.thanx/
This behaviour is correct but I can understand why you would question such a high consumption as many of our products can be configured to consume <50 mW when the output of the power supply is disconnected.
houston homes for sale , car finance , bad credit loans
Hello ohnate
During normal supply operation the CONTROL pin of the IC (which is both the feedback input and supply pin for the IC is supplied from the bias winding, typically 12-15 V). The consumption of the IC at minimum load (maximum feedback current) is therefore 12 V x 6 mA = 72 mW.
When the device is in remote off and no longer switching the bias voltage falls to zero. In this case the device consumption is supplied from the drain via a high voltage current source. There is no feedback current so IC consumption is 0.6 mA (ICD2 from datasheet). Therefore power consumption is 0.6 mA x VAC x Sqrt 2. At 115 VAC this is ~100 mW.
The good news is this performance meet all the worldwide energy efficiency requirements.
Cheers
PI-Chekov
