e-packge how will mount the heat sink
Posted by: Sathiyan.D on
Dear Sir, Please tell how will mount the heat sink external for e –spice package for top switch part no TOP261EN because there is no hole or drill to hold it. Our design Output power is nearly 160W, so we must use large heat sink. Please give the suggestion in this issue. With Regards Sathiyan.D Design Engineer Invent Solutions Private Limited India
Submitted by prasun on 08/28/2008
hello mr sathiyan, Specialty of E package is this that no drill hole or any other thing is required to mount the heat sink. A metal clip can hold the E package IC and this makes it very simple. Query & information about this clip could be better given by mr. checkov or PI team.
Submitted by PI-Spock on 09/04/2008
The esip package can be mounted onto heatsinks using a plastic or metal clip or strap. Please visit http://www.powerint.com/node/2893 for details on manufacturer information. These manufacturer parts are specially desinged for the eSIP package.
Submitted by micheal on 11/19/2009
Note that the damage from improper drive is not only due to thermal effects (though overheating is also possible) but due to exceeding the maximum optical power density (E/M field gradients?) at one of the end facets (mirrors) - and thus the nearly instantaneous nature of the risk student loans.
The optical output of a laser diode also declines as it heats up. This is reversible as long as no actual thermal damage has taken place. However, facet damage due to exceeding the optical output specifications is permanent. The result may be an expensive LED or (possibly greatly) reduced laser emission.
I accidentally blew one visible laser diode by neglecting to monitor the current but it wasn't the sudden effect some people describe - the current really had to be cranked up well beyond the point where the brightness of the laser beam stopped increasing chicago real estate. It did indeed turn into a poor excuse for an LED. One data point and you can conclude the world. :-)
Another one was blown by assuming that a particular driver circuit would work over a range of input voltages when in fact it was supposed to be powered from a regulated source. At first the degradation in brightness appeared to be reversible. However, what was probably happening was that damage to the laser diode was occurring as soon as the brightness appeared to level off. The natural tendency was then to back off and approach this same point again houston mortgage loans. Not quite as bright? Crank up the current. Finally, once it is much too late, the realization sets in that it will *never* be quite as bright as it was originally - ever again. This one still lases but at about 1/10th of its former brightness.
