MotorExpert 실행
Posted by: Anthony Kim
MotorExpert 가 윈도우즈 10 x64 버전(빌드 19042.1055)에서 커넥트 버튼을 누르면 에러 발생하고 실행이 안됩니다.
If MotorExpert presses the connect button in Windows 10 x64 version (build 19042.1055), an error occurs and it does not run.
윈도우즈 화면 캡쳐
(219.57 KB)
Hi Anthony,
Thank you for your interest in the MotorExpert tool!
It looks like there are no available Serial COM ports in your machine that the app can detect before establishing the connection.
You would also need an MCU running the BridgeSwitch Single-Phase BLDC Fan Motor Control Code Library for the MotorExpert application to connect with successfully.
The documentation for the code library is available in the Docs directory in the downloaded package.
PI-Potter
