Low cost - LED driver
I need some tip or guide to design a low cost 6W constant-current LED-driver.
I noted that, in general, transformer is a big source of cost, so I'm searching for
something like LNK306 that I can switch the mains power directly on the inductor,
without transformer to reduce the costs.
Requirements:
Input: 90-250 AC
Output: 6W with constant-current
Someone have a design like this?
Thanks for your reply, this power supply that you sugested me fits very well to my requirementes.
Do you have another design to the following requirements:
Low cost, without transformer
Input: 90-250 AC
Output: 9W with constant-current
I can't find an existing design but you can try to push LYT-0 to 9W by using higher VOUT. Output regulation over line may not be good but this is the closest design for a wide-range, transformer-less design.
what value of drumcore inductor can i use inplace of EE10 transformer.
If your design is similar to RDR355, then the inductance used was 1.35mH. You can try 1.2mH or 1.5mH if you are using a drum core.
Hi..i don't have much experience but as per my knowledge RDR-355 if it fits your requirement.The EE10 transformer can be replaced by a drum core. Also if your design is similar to RDR355, then the inductance used was 1.35mH. You can try 1.2mH or 1.5mH if you are using a drum core.
Please check RDR-355 if it fits your requirement. The EE10 transformer can be replaced by a drum core.
