LED Driver Using LinkSwitchTM-II LNK604DG
Posted by: Nanda Kumar on
I need to design 3W LED AC-DC Driver. I found LNK604DG is suitable for me. I need the design files such as schematics and board files.
Can you please share the same
Also I need to buy transformer which is used in this design. Am staying in bagalore.Please give me the contact infor the distributor of transformer
NAnda kumar M
Submitted by kmohan.np on 09/07/2015
Hi Nanda Kumar,
Please refer design DER351 which is 3W output LED driver suitable for your requirement &
it is designed using LNK604DG.
For transformer samples contact below mentioned transformer manufacturer,
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman","serif";}
Magnatech
D103, 2nd Floor, Industrial Estate, Rajajinagar, Bangalore - 560044
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
font-size:10.0pt;
Web: www.magnatech-india.com
with regards,
Mohan Kumar
800x600
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
font-size:10.0pt;
  Hi Nanda Kumar,
Magnatech
with regards,
Mohan Kumar
Submitted by adeelahmad on 09/16/2015
<p>Hello,<br />&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;i am working on RDR-257 circuit, can someone please tell me how to change its power. i mean to say which components should i change to make its power 36W.</p>
Submitted by PI-Dunwell on 09/17/2015
You can start by using the PIXls Software. Select LinkSwitch-PH Buck  from the Product line and input your specifications. The software will design it for you.
