Problem Kit RDR195
Posted by: elek.tuyen on
I measue all pin have value flow datasheet, but i not run. anybody help me?
Submitted by PI-Crumb on 09/06/2012
Please check the transformer windings orientation. On your schematic, you should interchange pin 1 and pin 11 in order for the converter to work in flyback configuration. Please refer to the transformer design of RD-195 for guidance.
Submitted by elek.tuyen on 09/06/2012
We make sample transformer for test in China. we have problem: size wire, material Core and tape different.
how can we make a new transformer following the specifications of the material we can find with our transformer manufacturer.
Submitted by PI-Crumb on 09/07/2012
You may use PIXLS spreadsheet to modify the transformer design. This design spreadsheet is part of PI Expert Software which you can download for free on PI website. Link: http://www.powerint.com/en/design-support/pi-expert-design-software
Once you install the software, please navigate to Power Integrations Folder and you can find PIXLS Designer 8. Click new and select LinkSwitch-PH. A new spreadsheet will appear which you can now use to modify your design.
