Clarification on the bad IGBT turn-on ( 2SC0535T2A1-33 driver)
Posted by: mikeh on
Attached is a screenshot from the oscilloscope showing a voltage pulse from the IGBT. We are using the 2SC0535T2A1-33 IGBT driver, but the turn-on voltage appears to be suboptimal.
Does anyone have insights into why this might be happening? Any suggestions or advice would be greatly appreciated.
Thank you!
Submitted by PI-IWH on 01/23/2025
Dear Mikeh
thanks for approaching us
to answer your question, first we need to have a common understanding about what the "good" gate voltage is and what the "bad" gate voltage is.
I will not spend so much time on that topic here, since everyone/company can have its own opinion/rules based on the actual application.
to make it simple, here are some points you can check if the gate voltage is ok or not during your low voltage evaluation
1- check the negative voltage value before turn-on according to datasheet
2- check the positive voltage value before turn-on according to datasheet
3- choose the right equivalent load for your measurement
4- calibrate the probe before the measurement.
5- check the driver delay according to datasheet
general feedback for "oscillation" on gate voltage
  • oscitation is cause by stray inductance in the whole gate loop and the capacitive load from IGBT
  • another import factor is the slew rate of the applied voltage source for this loop, which is defined by gate driver chip and gate resistor
  • assuming the gate loop design and gate resistor are fixed, the higher the slew rate is, the more oscillation you will observe from the gate voltage, while it is rising.
