2SP0115T2Do-17 and CM600DX-34T
Posted by: Horst
What values must the gate resistors (Rgon and Rgoff) have when using a CM600DX-34T modulu with the 2SP0115T2D0-17 driver?
© 2026 Power Integrations. All Rights Reserved
Dear Horst
Thanks for approaching us
Theoretically, the gate resistor shall not smaller than the given value in datasheet of the module
Practically, the value should be defined by the so-called double pulse test base a specific testing condition
You are encouraged to contact with local FAE from Power Integrations if you do not mind share your information here that is helpful for us to have contact with you.
Power Ingegrations
Gate Driver
