Wrong suggested part numbers when using PI Expert Online
Posted by: cprotopapas
I have used PI Expert online to design using the TNY286PG for an output of 12V, 1A. I am not sure how to send the design file online, but I made some changes of capacitor/resistor values, on the snubbing network input to the Drain.
The suggested part numbers for the capacitor are wrong. For the 22000pF - 33000pF range, most (or at least as many as I checked) capacitors are actually 2200 to 3300pF in value. That got confusing, I believe it should be rectified on PI Expert online.
Thank you for your feedback. By reviewing, there are some capacitors in the PI Expert database that needs correction, especially in the range of 22000pF-47000pF. We will fix these as soon as possible, and include it in the next PI Expert patch this April. Thanks again.
