Innoswitch3-Ep in non-isolated flyback
Posted by: E.A. on
I have depeloped a 50W isolated flyback with INN3678C-H606. Now, for another application, I need to use the same circuit but in not-isolated version. My question is if it is possible to connect the GND pin to the negative pole of the AC bridge rectifier, making a non-isolated flyback topology.
Do you see any problem for that? I attached an image with this connection in red.
Submitted by PI-Gavin on 01/30/2025
Hi E.A.
Thank you for participating in our PI forum.
Yes, implementing it that way should be fine. Though, we recommend to connect it and make a star connection to the GND terminal of your input capacitor instead.
Regards, Gavin
