Error in calculating power losses from direct current of the secondary winding of the LLC converter
Posted by: svarog46 on
Row 126   -Idc=1.5a
Row 133   -Rdc(100)=29.33m-ohm
Row 134   -Ploss both secondary =0.53W
BUT!!!  Ploss both secondary=1.5^2*0.02933*2=0.132W
WHERE IS THE ERROR ?
Submitted by PI-TOMMY BRADFORD on 04/15/2025
Hello svarog46,
Good morning and thank you for choosing Power Integrations.
Let me check this one with the relevant team internally. I will give an update as soon as I receive feedback from them.
Thank you and have a great day ahead.
Tommy
Submitted by svarog46 on 04/17/2025
Thank you. I'm waiting for your reply.
Submitted by PI-TOMMY BRADFORD on 04/21/2025
Hello svarog46,
Good morning.
The formula for the estimated power loss due to DC resistance (DCR_Ploss_Sec1) is as follows:
DCR_Ploss _Sec1 =  (IO1)^2 * DCR_100C_Sec1 * 2
where IO1  (row 14) is the maximum main output current and DCR_100C_Sec1 (row 133) is the estimated resistance per phase at 100 C.
DCR_Ploss _Sec1 = (3)^2 * 29.33 mΩ * 2 = 0.52794 W = 0.53 W
I hope that this clarifies your inquiry. Let me know if there's anything that I can help you with.
Tommy
Submitted by svarog46 on 04/22/2025
Hello Tommy
Thank you for your attention.
A pulsating current flowsthrough eachsecondary half-winding, which contains a constant and an alternating component
If for the alternating component the power is determined by
row 135 is multiplied by row 127 squared and multiplied by two- and the result is clear !
Then why is a different formula givenfordirectcurrent –where is the logic?
Submitted by PI-TOMMY BRADFORD on 04/23/2025
Hi svarog46,
Good day.
Just a quick note: the actual DC current that will flow continuously through each winding at full load is the maximum main output current listed in row 14, which is 3 A. Therefore, this is the parameter used to calculate the estimated power loss due to DC resistance (DCR_Ploss_Sec1).
I hope this clarifies the confusion. Thank you and have a great day ahead.
Tommy
Submitted by svarog46 on 04/23/2025
Hello Tommy
I do not understand this calculation, then why write in row 126 that the constant component of the secondary half-winding is 1.5 amperes
if it is not applied, but the load current is applied I looked at several articles there calculating the power as I wrote
Submitted by PI-TOMMY BRADFORD on 04/24/2025
Hello svarog46,
Good morning.
Let me check this one internally and will let you know as soon as there's an update.
Tommy
