Need non isolated 17W at 24V. Which chip?
Posted by: treez
We wonder whether its Tapped buck or non isol flyback etc etc?
We thought of tapped buck with LNK3209 but its fsw is only 66khz.
So we think of innoswitch...but it seems odd..because we dont need the isolation.
Just wondering abotu a non isolated topswitch flyback design too?
Thanks, vac input is 100-265vac
Hi Treez,
What is the input voltage?
LinkSwitch-CV can supply your required output power if the input is 230VAC (see datasheet: linkswitch-cv-data-sheet.pdf (power.com) )
You may also use LinkSwitch-HP (datasheet: linkSwitch-hp_family_datasheet.pdf (power.com) )
Both ICs are using PSR.
