Please add EF16 core to all design sheets for LYTSwitch 6 LYT 5228D
Posted by: A. Lehmann on
As the subject says, please add the EF16 core to all the design sheets for the above mentioned LED driver. (So Buck, Buck-Boost, Non-Isolated Flyback etc...). It is so far only available for Buck as far as I can tell, which already happened on my request.
Submitted by PI-Gavin on 06/12/2025
Hi Alexander,
Thank you for sharing this. We will relay your request to our team who handles PI expert.
Moreover, we have a simple way on how we configure magnetics if they are not in the drop down list. You may change the value to CUSTOM and put manually the magnetics parameters. You may follow what is also done in DER 959 (please see page 20). You may use the same parameter values since the DER is also using EF16.
Please let me know if you need any help.
Regards, Gavin
