LYTSwitch-0 buck-boost topology
Posted by: dzik1980 on
Hello
Can anyone help me to find design example for buck-boost topology for LYTSwitch-0 driver? In datasheet there is an schemaic "High-Side Buck-Boost – Constant Current LED Driver" but I cant find how to compute Rsens and inductance value?
Thanks for help
Submitted by PI-Zek on 01/31/2018
Can I please know the details of the design (input and output parameters)?
Design example or spreadsheet for calculation of LYTSwitch-Zero buck-boost design is not available. If you need a buck-boost topology, you can also refer to other LYT products. For example, buck-boost design calculation is readily available for LYTSwitch-1 design. I hope this helps. Thank you.
PI-Zek
Submitted by PI-Bombadil on 02/14/2018
Hello Dzik,
Can you try using LYT0005, 6800uH inductance, and Rsense = 127ohms? Then please let me know what happens.
However, I'd like to warn you that your output voltage, 280Vdc is too high and may cause the Vds spike to exceed the rating of the internal MOSFET and cause damage.
