Voltage monitoring for LNK-PL ICs
Posted by: pato2010 on
Dear PI engineers,
How to detect line undervoltage (UV), overvoltage (OV) for a specific range (for Example: 90-260VAC) using LNK-PL family.
Submitted by PI-Jono on 04/25/2015
There is no available pin used in the detection of line input for LNK-PL.  The part is for dimming application so emploring the UV will not be practical.  The UUT will shutdown during dimming and may cause flicker.
If it is for non-dimming, implement some external solution.  Use zener, resistor and transistor to build a under and ov detection circuit.
PI-Jono
Submitted by pato2010 on 04/29/2015
How to implement input overvoltage detiction circuit to shutdown the IC for 265VACin
Submitted by PI-Jono on 04/29/2015
It is possible to implement an OV protection as shown in the attachement.  Pull high the FB pin above 2V to disable switching.
PI-Jono
Sample circuit (10.28 KB) 10.28 KB
