simple non-isolated 30w CC PS
Posted by: sysWOW64 on
Dear engineers,  i am interested to use your LinkSwitch in our new LED power supply.  unfortunatly I failed to find suitable demo board for required parameters or parameter are not mentioned. Please, advise demo board schema for the followwing:
Input: AC 170-265, Output: 90-100V 300-350 mA Constant Current. PF > 0.95,  current ripple < 5%.
Driver should be simple and cheap, thats why non-isolated.
PS. Isolated solution we already have, but new ideas are welcome.
Submitted by PI-Dunwell on 08/07/2015
Please check this design example and see if its simple enough to meet your requirement.
http://led-driver.power.com/design-support/reference-designs/design-examples/der-405-25-w-high-efficiency-90-high/
Requirement is 300mA(better 350), 30w this example is only 150 :(
Submitted by PI-Dunwell on 08/11/2015
This is a sample design anf if the topology pass your criteria, you can redesign it for your particular specs using PIExpert software.
http://led-driver.power.com/design-support/pi-expert/
i used PI expert designer. What should do next after table ?
Harmonics table always fail ((
Submitted by sysWOW64 on 08/16/2015
In reply to by Alex Shabanov
Dear Alex, how to connect with you? Seems this company is far away from my answer.
Do you have mobile?
