Low cost - LED driver
Posted by: geraldo.gomes on
I need some tip or guide to design a low cost 6W constant-current LED-driver.
I noted that, in general, transformer is a big source of cost, so I'm searching for
something like LNK306 that I can switch the mains power directly on the inductor,
without transformer to reduce the costs.
Requirements:
Input: 90-250 AC
Output: 6W with constant-current
Someone have a design like this?
Submitted by PI-Crumb on 12/03/2015
Please check RDR-355 if it fits your requirement. The EE10 transformer can be replaced by a drum core.
Submitted by geraldo.gomes on 12/03/2015
Thanks for your reply, this power supply that you sugested me fits very well to my requirementes.
Do you have another design to the following requirements:
Low cost, without transformer
Input: 90-250 AC
Output: 9W with constant-current
Submitted by PI-Crumb on 12/09/2015
I can't find an existing design but you can try to push LYT-0 to 9W by using higher VOUT. Output regulation over line may not be good but this is the closest design for a wide-range, transformer-less design.
Submitted by chauhan.vision on 04/06/2016
In reply to by PI-Crumb
what value of drumcore inductor can i use inplace of EE10 transformer.
Submitted by PI-Crumb on 04/14/2016
In reply to by chauhan.vision
If your design is similar to RDR355, then the inductance used was 1.35mH. You can try 1.2mH or 1.5mH if you are using a drum core.
Submitted by DalDames on 06/09/2016
Hi..i don't have much experience but as per my knowledge RDR-355 if it fits your requirement.The EE10 transformer can be replaced by a drum core. Also if your design is similar to RDR355, then the inductance used was 1.35mH. You can try 1.2mH or 1.5mH if you are using a drum core.
pcb assembly services
