clamp design for LYT switches
Posted by: stalindm on
Hi, We are working on a 25W Led driver  High line design  using LYT4226. Kindly guide us to select the correct value of Snubber capacitor and Resistor for the primary clamp ckt( with high efficiency) . Excel design sheet shows only clamp power dissipation. Kindly share the correct procedure to find the correct clamp component values.
SDM
Submitted by PI-Crumb on 05/19/2015
Please refer  to figure 18 of the attached application note-59 for sample clamp circuits used in actual design.
p.13 also has some info about the clamp component selection. The amount of clamp you need depends on how much leakage inductance on the transformer so if you minimize the leakage, the less clamping you need.
Please measure the drain voltage to determine the maximum peak voltage that won't exceed the device rating.
an59.pdf (1.71 MB) 1.71 MB
Submitted by stalindm on 05/19/2015
In reply to by PI-Crumb
Thanks for your reply. We really interested to know How you got the component values of the RCD primary clamp.For  the design values - reflected output Vor  110V, Leakage inductance is 50uH, What is the equation to find the Cclamp and Rclamp in the case of LYT4226. Also provide the equation to find clamp dissipation too.
SDM
Submitted by PI-Crumb on 05/22/2015
I am sorry but if the info you are looking for is not in the application note, then please try to find generic articles about RCD clamp.
