Linkswitch-PL and DC input voltage
I have to know that the family linkswitch-PL can work properly with DC voltage on input of PSU?
I couldn't find the answere for my question. My psu have to work with universal 195-265Vac, but sometimes it have to work as emergency lighting. When this situation is present, the voltage on the PSU input will be 230Vdc.
Please tell me if I could use this family with DC input voltage.
With Best Regards,
TS
Ok,
Output LED: 12V, 0.45A
The PSU should work in two modes:
1. 230Vac input voltage. In that mode the PSU should cooperate with TRIAC dimmers.
2. 230Vdc input voltage. (without dimmer).
Do you have any suggestions? Which LED driver should I use?
With best regards
TS
Hi TS,
The suitable reference for your application is:
http://www.powerint.com/sites/default/files/PDFFiles/der296.pdf
It is secondary close loop which will force to regulate even with a DC input. The reference is a dimmable and follow the circuit description in the report for more details.
Use the PH-spreadsheet for your transformer design. The transformer design calculator can be downloaded in this link:
PI-Jono
Hi TS,
LinkSwitch-PL family is not designed for DC input. It will enter to auto-restart mode.
An alternative part would be LinkSwitch-TN. Please provide us the basic specification for us to check.
PI-Jono
