LED Lightning Product
Hi. I Am Chandresh Ghodasara From india.i am starting my new business in LED lightning. i want to develop LED products as under.
1) LED Street Light - 12W,30W,40W,60W,90W,120W,140W,200W.2) LED Flood Light - 10W,30W,60W,90W,120W,200W.3) LED Tube Light - 3W,6W,10W,12W,18W,20W,24W.4) LED Bulbs - 1W,2W,3W,4W,5W,8W.
I am Electronics Students. I wanted Circuit Diagram, PCB Layout, LED Arrangement diagram and Every Complete Details About circuit (each watt separately).
IF i can get detailed information about LED Lightning Products Please Let Me Know.Also Suggest Me the Type Of led To be Used.
Thanks,Chandresh GhodasaraINDIA
thanks for your warmth reply.
But can i use it for my product designing?? the same schematics??
If it matches your specs and the performance data meets your specs, you can use it.
You can also use the PIExpert Designer for design. It will give you the transformer and basic circuit diadram to start with your design. You can download the software from this site
where can i get ready winded transformers??? I need to talk to you do u have any other source where we can talk online??
You can get the transformers by following the instructions on this site
http://www.powerint.com/en/design-support/rapid-transformer-samples
If you need more support, I believe our sales offices in India will be more comfortable for you for your other inquiries. Pls feel free to contact them. They have technical FAEs to answer your technical needs.
http://www.powerint.com/en/company/sales-information/worldwide-sales-support-locations
how to arrange led? in series or parallel? which type of led to use and what amount for the drivers?
Ideally it should be conncetd inseries so all LEd share the same current. There are lots of type of LEDs available and you should check the specs to determine the driver requirement
The drivers that is mentioned here is ok but what about the other drivers such as 35W,40W,50W,60W,70W,80W,90W,100W,110W,120W,130W,140W,10W,170W,180W,190W and 200W.
where can i get circuit diagram,PCB layout and BOM of the above Watts?
You can use the Reference designs as a reference for your projects. If it exactly matches your specs, you can use it. If you need a complete design for every requirement that you have, again I suggest you to communicate with the local PI sales office in your area for you to get full support.
Dear Mr.Chandresh Ghodasara
we are in chennai , we are design the LED driver and and MC- pcb if need more details
conduct my moblie as well as mail
+91-9677029460
V.manikandan
You can check this site.
http://www.powerint.com/en/applications/led-driver-ics/led-design-selector
You can find there a lot of design engineering reports for LED Drivers built for industrial, commercial, and residential applications. Each report contains schematic, BOM, PCB Layout ang Performance Data.
