CC circuit
Hi, I am going to design a Led Driver 48V@350mA using TNY280PN , so need to add CC circuit ,so please tell me how to design CC ,and what should be the rating of transistor and about its regulation ?
Will be it within 10% or not ?
I don't want to use LKN-PH device.
Pls suggest assp.
In DI-173 , transistor being used is of 40V and U2 is LM321, can we have the CC ckt with the help of two or three transistor MMST2222 , but my o/p is of 40V@350mA .
Please guide me, I want to go with transistor only.
Please suggest assp.
Thanks for your prompt response.
DER35 with link below can be used using single transistor and a zener diode.
http://www.powerint.com/sites/default/files/PDFFiles/der35.pdf
If you need a low drop cc, pls refer to the link below
http://www.powerint.com/sites/default/files/PDFFiles/der113.pdf
You can check the link below for a CC circuit using TinySwitch-III
http://www.powerint.com/sites/default/files/PDFFiles/di173.pdf
