Clarification on the bad IGBT turn-on ( 2SC0535T2A1-33 driver)
Posted by: mikeh
Attached is a screenshot from the oscilloscope showing a voltage pulse from the IGBT. We are using the 2SC0535T2A1-33 IGBT driver, but the turn-on voltage appears to be suboptimal.
Does anyone have insights into why this might be happening? Any suggestions or advice would be greatly appreciated.
Thank you!
(537.43 KB)
Dear Mikeh
thanks for approaching us
to answer your question, first we need to have a common understanding about what the "good" gate voltage is and what the "bad" gate voltage is.
I will not spend so much time on that topic here, since everyone/company can have its own opinion/rules based on the actual application.
to make it simple, here are some points you can check if the gate voltage is ok or not during your low voltage evaluation
1- check the negative voltage value before turn-on according to datasheet
2- check the positive voltage value before turn-on according to datasheet
3- choose the right equivalent load for your measurement
4- calibrate the probe before the measurement.
5- check the driver delay according to datasheet
general feedback for "oscillation" on gate voltage
