Level mode Switch on drivers SCALE™-2+ 2SC0115T2A0-12, 2SC0115T2A0C-12
It is stated that multilevel or 2 level mode is available for SCALE™-2+ 2SC0115T2A0-12, 2SC0115T2A0C-12 drivers. But when I checked the manual and datasheets, I could not see how to switch between these modes. There seems to be no pin or switches information on this. Could you help me figure out how it is adjusted?
I have sent images in attachments that shows this driver can be used on 3 Level NPC topologies but I could not see any mode switches on schematics or anywhere else. I could not figure out how it is adjusted to 2 Level or 3 Level modes.
| 2SC0115T_1.png (53.38 KB) | 53.38 KB |
| 2SC0115T_2.png (80.58 KB) | 80.58 KB |
Dear
2SC0115T2A0-xx is a two gate channel driver solution , whose target is a half-bridge basic topology.
you can use this two channel solution to driver your NPC topology as well in a system level.
the point is that the we have customers is using 2SC0115T2A0-xx to build their NPC system , the driver has corresponding figures to make sure the system running in a protected way
Dear
Could you please show here where you find this statement, which will be helpful for us to do precise support
the purpose is to understand your question clearly first before we provide any answer.
thanks
