gate resistors for 1SP0635 when driving a 1MBI2400VC-120P
Posted by: n.werner@m-pulse.eu on
We are using a 1SP0635 gate driver to drive a Fuji 1MBI2400VC-120P. Due to availability problems we purchased gate drivers _without_ any gate resistors. Could you name recommended gate resistors for the aforementioned combination?
Best Regards
Norman Werner.
Submitted by PI-IWH on 02/06/2022
Dear Norman
Thanks for approaching us.
First, please make sure the gate driver you purchased is for 1200V voltage class.
Second, you can refer to "1SP0635x2xx-1MBI1600V-120P" datasheet as the start point to find suitable gate resistors for your system. Rg,on is 3R, Rg,off is 0.5R.
Here is the link to the datasheet "https://www.powerint.cn/sites/default/files/documents/1SP0635x2x1-1MBI1600VC-120P.pdf"
Note: this is a dedicated driver for 1MBI1600V-120P, and here is only a recommendation of a reference that you can work on for your target IGBT
Gate Driver Support
