Unable to do optimization
I have created the design and want to optimize it but the button "start optimization" is grey and not clickable. In tutorial videos optimization panel appears right after creating the design. Also, I can't see the value of efficiency in the design evaluation section. It only shows on graph but I couldn't find where to get numerical value. Right click then copy data doesn't work. I will be glad for any help. Thank you!
Hi, you can find the design below;
https://piexpertonline.power.com/fileManager/index?shared=e35f9713f9af46ffaf3d0b48a27f76e2116f87af5e4be13b4da8f4297ce432d6
My task is to compare the efficiency of my design with its different variations by making small changes of components.
Hi, I still have the issue. Waiting for help, thank you!
Hi Gonur,
Unfortunately, PI Expert dedicated for InnoSwitch4-Pro is currently in its beta stage. Therefore, certain features have not yet been implemented.
Hi gonur,
Good day, and thank you for choosing Power Integrations.
To help us better understand and assist you further with your inquiry, could you please share the design file where you are encountering the issue? It would be appreciated also if you can provide your target specifications.
Thank you!
