Problems with INN3165C
Posted by: Nujiy
1)Can I change the number of valleys in QR mode to start conduction?
2)How do I change from DCM mode to CCM mode? Need to change the parameters of the load?
Jun Yi!
(37.68 KB)
Hello Jun Yi,
To answer your questions)
- The number of valleys is decided by the IC depending on the energy needed by load at the time so it cannot be controlled externally.
- You can change whether the converter is working in DCM or CCM mode in the simulation by changing the input voltage level. You can see this in the DER report.
| DER 538 Steady State Waveforms.PNG (218.39 KB) | 218.39 KB |
This is an emulation inside DER-538
