Issue R1 and VR4 Failure in DER-622-Based Power Supply
Posted by: lupinn on
I’m working on a power supply design based on the DER-622 reference circuit using the LinkSwitch-TN2 (LNK3202D). My application is a 2-wire (no neutral) system supplying a load of approximately 20–50W.
Recently, both R1 (20kΩ/1206) and VR4 (43 V Zener diode) were damaged (burned) during operation.
I understand that:
  • R1 is intended to limit inrush and standby current.
  • VR4 is supposed to bypass R1 during startup or when higher current is needed.
Symptoms:
  • R1 was visibly burned.
  • VR4 failed (likely shorted or open).
  • The circuit stopped functioning entirely.
Possible suspects:
  • bulk capacitors may have shorted.
  • LNK3202D may have internally failed.
  • High inrush current or a downstream short may have caused R1 and VR4 to overload.
  • AC input surge or relay malfunction.
Request for help:
  • What is the best way to prevent R1 and VR4 from being damaged under such conditions?
  • Are there recommended modifications to R1, VR4, or protection circuitry for handling 50W loads reliably?
  • Should I lower the R1 value or increase Zener power rating?
Any insights or practical suggestions from experience are highly appreciated.
Thanks in advance!
Submitted by PI-Gavin on 06/10/2025
Hi, Can you share your schematic and layout files so we can review accordingly?
-Gavin
Submitted by EmilyWalker on 06/16/2025
Component stress can often cause R1 and VR4 failures. A solution could involve fine-tuning feedback and protection circuits. The TS472IQT, with its built-in op-amp and high-performance audio features, can serve in voltage sensing or signal conditioning roles, improving response and durability in high-voltage AC-DC applications.
Submitted by PI-Gavin on 06/17/2025
Hi Emily,
Just making sure, are you using DER 622 for 20-50W on the load?
The DER's flyback section is only designed to deliver 0.25W, in this case, to power up the bluetooth module. R1 and VR4 can be damaged with a higher current flowing through it. Can you check your connection and ensure the load is connected properly as how it is indicated in the DER? What is your line voltage?
Regards, Gavin
