InnoSwitch4-QR. Using a SR FET with gate threshold voltage higher than 4.5V
Posted by: alberto.mari.m… on
I'm working on a design where I have an InnoSwitch4-QR and a 24V output. The datasheet says that the SR FET driver uses the SECONDARY BYPASS pin for its supply rail, and this voltage is about 4.5 V, therefore SR FETs with a gate voltage threshold voltage range Vgs(th) of 1.5 V to 2.5 V are recommended.
 Anyway, I would like to use SR FETs with a gate threshold voltage higher than that. I was thinking about putting a gate driver IC between the SR pin and the gate of a 5V-threshold FET.
Is there anyone here who has done this before? Or any application note where this idea has been put forth?
Submitted by PI-Book of Pi on 02/16/2025
Hi Alberto,
We currently don't have any implementation like this wherein an external gate driver is used across the SR Pin to control the switching of an SR FET.
There are also major concerns in the timing of SR Pin (when it will pull high and low the signal as its output) when operating in DCM as the SR Pin relies on the signal seen by the FWD Pin with respect to the secondary GND Pin, so adding a high input capacitance system (external Gate Driver) will affect the timing.
May I inquire what are the reasons why would you want to use a 5V of Vgs(th) for your FET?
You can also find more specific details on choosing SR FET by checking page 18 of the design guide below:
an-72_innoswitch3_family_design_guide.pdf (power.com)
Submitted by alberto.mari.m… on 02/19/2026
Hi PI-Book,
In my opinion it is quite difficult to find 150V logic-level power FETs from the major manufacturers (Onsemi, Vishay, Diodes, Infineon, Nexperia, STMicro, Diotec, etc...) especially in low-profile SMT packages like DFN3333 or DFN5060. That's why I was asking if there is a way to increase the drive voltage.
Another option is to use GaNs as SSR FETs instead of standard mosfets. I have seen a few interesting parts, but I don't know if there are other implications to take into account. I have started a new thread on the issue here
I have some questions about AN-72:
  1. In the requirements, you state that Crss should be less than 35pF and Crss/Ciss < 2%.
    1. Crss and Ciss are not fixed values: they vary substantially with VDS. This is an example. Which point of the curve should I take as a reference for evaluating Crss and Ciss?
    2. Do these two requirements need to be verified at the same time? I mean: is it ok if we chose a FET with Crss>35pF, but with Crss/Ciss<2%? or viceversa, is it ok if we chose a FET with Crss/Ciss>2% but with Crss<35pF?
  2. Regarding the requirement on the body diode recovery time Trr<40ns. I guess this requirement is important only when the flyback works in CCM, as in this case it is "hard-switched". If we design a flyback that can work only in QR mode, the diode is "soft-switched" and the requirement on Trr is not important.
Crss_Ciss_Coss (84.67 KB) 84.67 KB
