Clarification on RDR-1002 (InnoSwitch5-Pro + IP2756) Communication and Testing Software
Posted by: TEMC on
I am currently working with the RDR-1002 140W USB PD 3.1 Extended Power Range (EPR) Evaluation Board, which includes the InnoSwitch5-Pro (PowiGaN), HiperPFS-5, and the Injoinic IP2756 USB PD Controller.
I would like to perform testing and control operations on the InnoSwitch5-Pro through the IP2756 PD controller. However, I couldn’t find documentation on:
The software tool or GUI required to communicate with the IP2756 (for sending I²C or PD commands to the InnoSwitch5-Pro).
The command set or communication protocol details (PI command set) used between the IP2756 and the InnoSwitch5-Pro.
Any reference scripts, firmware examples, or host interface documentation for PC-based control or testing of the RDR-1002 board.
Could you please guide me on where to find this information or share the appropriate documentation/software tools for controlling and testing the InnoSwitch5-Pro via IP2756?
Design form (14.6 MB)
Submitted by PI-Prowler on 10/10/2025
Hi TEMC,
The RDK-1002 comes completely built with the IP2756 USB-PD controller already programmed.
You can confirm the USB-PD source capabilities if you have a sink device that supports USB-PD protocol.
In Standard Power Range (SPR) mode, the following Power Delivery Objects (PDO) are accessible.
  • 5 V / 3 A FPDO
  • 9 V / 3 A FPDO
  • 12 V / 5 A FPDO
  • 15 V / 5 A FPDO
  • 20 V / 5 A FPDO
If you have a sink device and a USB-C cable that can support Extended Power Range (EPR) mode, in addition to the PDOs available in SPR mode, the following PDOs also become accessible.
  • 28 V / 5A EPR FPDO
  • 15-28 V / 5A EPR AVS APDO
If you are asking for the reference/documentation providing information on how to program the IP2756 USB-PD controller, how it handles the PD transactions/messages, or how it communicates to the InnoSwitch5-Pro, you may need to communicate directly with the IC manufacturer as the IP2756 is a third-party product and is already programmed with the necessary firmware to control the InnoSwitch5-Pro in RDK-1002.
You can monitor the I²C communication through the SDA, SCL and GND pins of the InnoSwitch5-Pro IC to know which registers are being written/read during normal operation of the evaluation board. The InnoSwitch5-Pro Datasheet provides the guide on how our product handles I²C communication and how to access all available command and telemetry registers of the InnoSwitch5-Pro.
https://www.power.com/sites/default/files/documents/InnoSwitch5-Pro_Data_Sheet.pdf?language=en
Thank you for using PI Forum.
