TOP 265 Not turning ON at lower Voltages
Posted by: shwetaspt0 on
Using top265 Input 19.2 to 373DC has been designed now I am trying it to extend for 5W. for higher voltage it is working fine. but at 19.2V it is not turning on and with some changes even it got tuned on then after some time input current start increasing (also the temperature) which is might be causing thermal shutdown.
Please suggest some solution do we need to go for higher rating TOP switch
Submitted by PI-Wrench on 06/03/2024
What is your actual intention for this design? Do you really want to run the full range from 19.2 to 373VDC? If you do not need the high voltage capability. a DPASwitch may be a more appropriate choice for your needs. Also, at the lower voltage, you might want to check the drain waveform to make sure that you are not running into the max duty cycle limit.  What does the design spreadsheet tell you about the peak current at low input voltage? That will be the guide for determining whether you need a TOPSwitch with higher peak current rating.
I actually tried running a spreadsheet for this design - after some massaging, I got it to work. What is your target output voltage and operating frequency? Running a TOP266  may be a solution for this design, as the larger mosfet in the TOP266 will have a lower voltage drop at the peak current associated with the output power you are seeking.
Submitted by shwetaspt0 on 06/03/2024
1.Yes I need full range 19.2 to 373V,output 12V 5W.
2.It is not crossing maximum duty limit in any operating voltage range.
3.Operating frequency is 132kHZ
4.Tried with spreadsheet(keeping 25V to 373V as 25 is the lowest possible value it allows to enter) but its showing error of maximum duty reached to 0.932.
Submitted by PI-Wrench on 06/04/2024
You can correct the duty cycle problem by varying the reflected output voltage of the transformer (VOR). I had to crank the VOR all the way down to 50V to get a reasonable duty cycle that was within the maximum limit of the TOPSwitch. Such a low VOR forces you to use an output diode with a relatively high PIV, as this results in a secondary winding with high output voltage at the max limit of your input voltage range. I had to choose a very large input cap and a ridiculously high AC input frequency to get results that would approximate DC input. I have appended a PDF of the spreadsheet in question for your information.
TOPSwitch-JX TOP266_5W DC input.pdf (36.96 KB) 36.96 KB
Submitted by shwetaspt0 on 06/19/2024
Is there any limitation related to negative switch current (source to drain current )?
In the below picture it is 400mA ? is there any maximum allowable value for it.
Negative current_0.png (603.62 KB) 603.62 KB
