PI Expert only does Innoswitch Flybacks?
Posted by: treez on
Every time i try and do a TOPswitch JX design in PI Expert or PI XLS, it always reverts to Innoswitch
even though i chose TOPswitch JX. How do you stop this?
Submitted by PI-Waer on 12/26/2024
Hello Treez,
Can you give some more details about the issue you are encountering?
I tried making a PI Expert design using TopSwitch-JX and I was able to generate one successfully.  I am not sure what is causing your issue but if you can walk me through what you do leading up to the issue, we may be able to find a solution.
I will link the design I generated below so that you can start a design in the meantime.
PI Expert: https://piexpertonline.power.com/piexpert/design/select?share=ddc052b63a297c252ea0990ee720e574799129ce56f9c0d0b0d31611eac2a346
Submitted by treez on 12/26/2024
Thanks,  now i managed it when i clicked into the TOPswitch-JX product page and went into "start design" from there.
When i just go into "start design" from the Power Integrations (other) pages...it always reverts to Innoswitch.
