Magnetic designer - planar transformer
Posted by: vlada.svoboda@…
How to interpret magnetic designer result regarding the core needed?
There are instruction to put together E core plus Plate, but according to stack high two E cores should be used.
At the same time, there is reference about nominal inductance and gap size, but there is no solution how to solve it.
regards
Vladimír
Hi Vlada,
please switch the core material to PC95 where you will find EIR22 core (e-core plus flap).
Later, you can create your own component EIR22 in 3F3 variant.
Design export added...
