Innoswitch design notes with vout = 23v or more? Posted by: treez on 12/27/2024 Hi, Would be most grateful if your office could list DER notes etc on PI site which discuss innoswitch designs where vout is 23v or more? 回應 Hi treez, Here is a list of InnoSwitch DERs with output voltage of 23V and above: DER 712: https://www.power.com/design-support/design-examples/der-712-60-w-ultra-wide-input-range-adapter-using-innoswitch3-ep-750-v-powigan-switch-and-mine-cap DER 571: https://www.power.com/design-support/design-examples/der-571-40-w-dual-output-power-supply DER 815: https://www.power.com/design-support/design-examples/der-815-45-w-24-v-output-isolated-flyback-power-supply-smart-speakers-and-tubular-motors-using-innoswitch3-cp DER 903: https://www.power.com/design-support/design-examples/der-903-72watt-charger-93pct-efficiency-using-innoswitch3-cp-powigan DER 915: https://www.power.com/design-support/design-examples/der-915-84watt-charger-93pct-efficiency-using-innoswitch3-cp-powigan DER 957: https://www.power.com/design-support/design-examples/der-957-130-w-usb-pd-3pt1-epr-charger-powigan-innoswitch4-cz-clampzero-hiperpfs-5 DER 966: https://www.power.com/design-support/design-examples/der-966-140-w-usb-pd-3pt1-epr-charger-powigan-innoswitch4-cz-clampzero-hiperpfs-5 DER 1002: https://www.power.com/design-support/design-examples/der-966-140-w-usb-pd-3pt1-epr-charger-powigan-innoswitch4-cz-clampzero-hiperpfs-5 DER 1046: https://www.power.com/design-support/design-examples/der-1046-180-w-usb-pd-31-epr-charger-notebooks-and-power-tools-using-powigan-based-innoswitch5-pro-and-hiperpfs-5 DER 1021: https://www.power.com/design-support/design-examples/der-1021-150-w-2-stage-boost-and-isolated-flyback-3-way-dimmable-led-ballast-using-hiperpfs-4-and-powigan-based-innoswitch4-qr DER 1038: https://www.power.com/design-support/design-examples/der-1038-100-w-low-profile-led-driver-using-innoswitch4-qr-750-v-powigan-capzero-2-and-hiperpfs-4 DER 1033: https://www.power.com/design-support/design-examples/der-1033-130-w-isolated-flyback-197-w-peak-power-printers-using-innoswitch4-qr I am hoping that this helps. Have a great day ahead! Kind regards, PI-Zoe
Hi treez,
Kind regards,
PI-Zoe
