In DER535 what does heat spreader connect to?
Posted by: treez on
Hi, DER535 shows a metal heat spreader being right under the board and separated by insulating pads. To which circuit node does this metal heat spreader connect, or is it just floating?
https://www.power.com/sites/default/files/documents/der535.pdf
Submitted by PI-Gavin on 01/02/2025
Hi treez,
Thanks for posting in our PI forum.
The metal heat spreader in DER-535 is left floating. You may check the PCB layout on pages 10-11 and see that the holes does not have any connection with the rest of the circuit. Thank you.
Regards, Gavin
