URGENT DATA REQUEST FROM FLEX FOR PART NUMBER LNK302DN-TL
Posted by: Siddesh Chavan on
Hi POWER INTEGRATIONS Team,
This is Siddesh from Flex Component Engineering Team.
We are working on some of your manufacturing parts and require information on the below questions.
Could you please provide below MPN details as quick as possible as it's an urgent request from our site.
End Customer: CHARGE POINT
Flex Manufacturing Site: Guad South (Mexico)
ITEM NUMBER: CTI1H-14-002154-01
MPN_DESCRIPTION: IC, OFF-LINE SWITCHER SO-8C
MANUFACTURER PART NUMBER (MPN): LNK302DN-TL
1. ABOVE DESCRIPTION MATCHES WITH MPN ? (YES / NO) ?:
2. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT / INVALID ?:
3. IS THIS MPN AVAILABLE IN TAPE & REEL PACKAGING OPTION ? (YES / NO) ?:
4. IF YES, PROVIDE US CORRECT & ORDERABLE TAPE & REEL PART NUMBER ?:
5. PROVIDE US CORRECT & ORDERABLE PART NUMBER FOR PURCHASE ORDER #PO ?:
6. LIFE CYCLE STATUS (ACTIVE / OBSOLETE / NRND) ?:
7. IF NRND, PLEASE PROVIDE US LTB AND LTS DATE ?:
8. IF OBSOLETE, SUGGEST US EXACT DROP-IN REPLACEMENT WITH SAME FFF ?:
9. MOUNTING TYPE: SURFACE MOUNT TECHNOLOGY (SMT) ? (YES / NO) ?:
10. MOISTURE SENSITIVITY LEVEL (MSL) ?:
11. PART MARKING ?:
12. PACKAGING TYPE (TAPE & REEL, ROLL, TRAY, TUBE, AMMO, BULK etc.) ?:
13. ROHS COMPLAINT ? (YES / NO) ?:
14. DATASHEET LINK // DATASHEET IN PDF // SPECIFICATION SHEET // DRAWING SHEET:
Looking forward to your quick response.
NOTE:
• MSL: The MSL is the MOISTURE SENSITIVY LEVEL of the material. There are some levels that manifest the amount of time and the humidity that the material can handle before baking it.
• Part Marking: It is the printed marking on the top side of a part.. For example, it may contain date code, country of assembly, manufacturer logo, etc. Part marking/Top Marking is the unique code mentioned on the device to identify the part details.
• NRND: Not recommended for New Design
• LTB: Last Time Buy Date
• LTS: Last Time Shipment Date
• FFF: Form, Fit, Function
• SMT (Surface mount Technology) : Surface mount devices are directly mounted onto a PCB and do not have protruding leads.
SIDDESH CHAVAN
siddesh.chavan@flex.com
Submitted by PI-Lupin the Third on 05/20/2023
Hi Siddesh Chavan,
Thank you for your inquiry regarding the part LNK302DN-TL. Here is the information you requested:
The part is currently available for order in tape reel packaging.
It is both RoHS-compliant and Halogen-free, meeting environmental standards.
LNK302DN-TL is a surface mount device (SMD) with a Moisture Sensitivity Level (MSL) 1.
The part is marked as "LNK302DN."
The datasheet and drawing are on our website, providing detailed specifications and technical information.
Please feel free to reach out if you have any further questions or need additional assistance.
Best regards,
PI-Lupin the Third
