Split Primary in PI Expert Web
Posted by: powerlion on
How can I specify a split primary in PI Expert Web?
PI Expert Desktop allowed this in the left panel under winding construction options.
Thanks in advance.
Best
Submitted by powerlion on 03/06/2023
If you are an old timer like me who just moved to PIExpert Web from PI Expert Desktop. The split winding can be enabled in Magnetics Designer Tab.
Click on the Primary coil in the Electrical Diagram Window. Then select split drop down to series in the Winding Properties window.
Thanks!
Split Primary.png (287.67 KB) 287.67 KB
Submitted by PI-Pompeii on 03/07/2023
Hi, good day!
You're absolutely right. You can enable and disable split winding by going to the Winding Properties Window > Scroll down to Split > Click the blue button beside it and use the dropdown arrow.
Additionally, you can click on the primary coil not only in the Electrical Diagram window, but also in the Mechanical Diagram window. There you can click on any winding, drag and drop them, or do some other actions by right-clicking on them.
Thank you for taking the time to share your knowledge.
Have a great day!
