INN3649C-H606 based 62Watt and 42Watt Design
Posted by: harshad.rank on
As per requirement need to generate SMPS design from 150VAC to 500VAC supply range for more than 60Watt.
So, I have selected INN3649C-H606 device which cover the input range.
PI Onine do not support this device so taken reference from other low voltage design.
I have attached the schematic as well as transformer design. Will it work ?
Submitted by PI-Martok on 08/04/2023
Hi Harshad,
       Thanks for using PI products.  You can use INN36X9 in device selection disregarding the primary voltage stress (VDRAIN_OFF_PRSW).
Mark
Submitted by Skywalker on 08/04/2023
As shown in the Inno3-EP datasheet, the maximum input voltage is 400 VAC for the 900 V PowiGaN Switch.
500 VAC input is too high for the 900 V PowiGaN devices.
Hi Skywalker
     Harshad will be using INN3649C-H606 which is 1700V rated with Input range from 85VAC-670VAC.
Submitted by harshad.rank on 08/13/2023
Thanks for comments
Could you please comment on earlier attached schematic and transformer design?
Can we go ahead with schematic(INN_SMPS_SVG_01.pdf) and transformer design?
regards
Harshad Rank
Submitted by Skywalker on 08/14/2023
Hi Harshad,
You are going to use the same INN3649 with increased current limit for both 42 W and 62 W application.
  1. Effective Input capacitance can be reduced to 200 uF from 470 uF
  1. With 1700 V device,
    1. For 42 W design,
      1. Recommended to review your PIXL data
      2. Primary inductance can be around 300 uH, not 500 uH
      3. VOR value can be higher to lower the FWD and SR FET voltage stress,
      4. It is recommended to add 330 pF between FWD and GND pins to lower the FWD voltage stress during start up
    2. For 62 W design
      1. VOR value can be higher to lower the FWD and SR FET voltage stress,
      2. It is recommended to add 330 pF between FWD and GND pins to lower the FWD voltage stress during start up
Submitted by harshad.rank on 08/16/2023
Hi Skywalker,
  1. Yes we are going to use the same INN3649 with increased current limit for both 42 W and 62 W application.
  2. Yes we will reduce Input capacitance to 220uF from 470uF
      With 1700 V device,
      For 42 W design,
      In our design there is -15V output so with PIXL, when we select -15V then it shows problem: Calculation error has occurred.
      We can change VOR to up to 125, if we we go higher than that then it gives warning to decrease FS. At VOR value to 125 Primary inductance goes down to 449uH from            461uH.
      3.      It is recommended to add 330 pF between FWD and GND pins to lower the FWD voltage stress during start up
      Ok we will add 330 pF between FWD and GND pins.
    For 62 W design
  1.      It is recommended to add 330 pF between FWD and GND pins to lower the FWD voltage stress during start up
Note: We have generated this design using PI Expert 10.3 (for 900V Device and same used with 1700V Device)
regards
Harshad Rank
