EFD15/8/5 Flyback at highest power ?
We wish to use a power integrations controller to get the max power that we can get out of a EFD15/8/5 flyback
100-265vac
24vout
isolated to 3000VAC
Open frame
There is reasonable amount of blown air....ambient temp around transformer will be 45degc max.
Do you know what is the max power we can get?, and what Power.com controller should we use.?
Thanks, but i still find PI expert and PIXIS designer dont like you changing stuff, like the transformer...even if its possible, they wont work it out.
I can do it myself..but boss wants to see PI Expert solution.
The reason why PIXls cannot provide a solution within the restrictions is because it is very unlikely such a design to fly in a mass production.
I would suggest seeing our local representative for detailed discussion of the requirements. Our FAE's have a lot of experience with finding solutions for tough design requirements.
Hi, thanks for the interest in Power Integrations products.
The maximum power out of a particular core is subject of many design constrains and compromises.
Please try our excellent tool on https://piexpertonline.power.com/site/index. For experience users and corner experimental designs you can use PIXLS platform.
Most likely the smallest InnoSwitch3-CE controller will do the job.
