Difference between Innoswitch CE, CP and EP?
Posted by: treez
Is the only difference between Innoswitch CE, CP and EP just the VDS, the Current limit , the RDSon and the bias current?
© 2026 Power Integrations. All Rights Reserved
You will notice that Voltage and current characteristic curve differs for CE and CP. CE is typically used for chargers with tight CVCC curve requirements while CP has Constant Power region. EP is usually device the is used for Extended Power requirements.
Jedidiah
