wide range smps 100vac to 500vac Posted by: jayesh0628 on 02/08/2022 i want to design wide range smps using TNY series. input : 100vac to 500vac output : 1. 12v 0.6 A 2. 5v 2A 回應 There is not a readily available design utilizing TinySwitch, but this InnoSwitch design might suffice: https://www.power.com/design-support/design-examples/der-889q-15-w-power-supply-800-v-bus-30-1200-vdc-input-using-innoswitch3-aq
