Standards and test certifications
Posted by: aru
INN3270C inno switch, what are the test certification having and is it compatible with MIL standards
© 2026 Power Integrations. All Rights Reserved
Hi Aru,
Thanks for checking our products.
The InnoSwiitch3-CP family (INN3270C) is compliant with EN/IEC 62368-1, IEC 60950-1, UL1577, GB4943-1 standards and is used for different applications.
However, our knowledge for MIL standard is much limited. I would recommend to consult with your compliance expert to check the specific MIL requirements (i.e. spacing, hi-pot, etc.) that are applicable for our product to satisfy. Full evaluation for MIL compliance should be considered in the end product or system. I hope it helps.
Kazuya
