Please recommend AC/DC conversion solution with non-isolated output
Posted by: LW
Currently I try linkswitch 3206 with 24V non-isolated output, it works fine with 5~6W output, can you recommend
higher output over 20W non-isolated solution? over 40V non-isolated output is fine.
can TOPSWITCH series re-config as non-isolated toplogy?
Thanks!!
Attached is a paper on using TOPSwitch in a non-isolated buck converter.
| 첨부 파일 | 파일 크기 |
| top switch Buckconverter_0.pdf (72.15 KB) | 72.15 KB |
Are you looking for a buck solution or a non-isolated flyback?
