Please recommend AC/DC conversion solution with non-isolated output
Posted by: LW on
Currently I try linkswitch 3206 with 24V non-isolated output, it works fine with 5~6W output, can you recommend
higher output over 20W non-isolated solution? over 40V non-isolated output is fine.
can TOPSWITCH series re-config as non-isolated toplogy?
Thanks!!
Submitted by PI-Wrench on 02/09/2022
Are you looking for a buck solution or a non-isolated flyback?
Submitted by PI-Wrench on 02/18/2022
Attached is a paper on using TOPSwitch  in a non-isolated buck converter.
top switch Buckconverter_0.pdf (72.15 KB) 72.15 KB
