Pi Expert 2.7.0.42 Magnetics database issue
Posted by: Tomeco
The engine for the Component library has changed. I don't quite understand it.
I added my own core in the Magnetics database (in that weird copying way) Fig.1.
Then when I go into the project and try to select this core in the "Core selection" dialog, it is not there Fig.2.
What am I doing wrong?
Thanks, this works.
Hi Tomeco.
Thank you for reaching out to us.
Most likely the problem is that you did not link any bobbin to your custom core. If the core does not have any bobbin associated with it, PI Expert will not be able to actively use it on any design.
To link one or more bobbins to your custom core follow the steps below:
Hope this helps.
Best regards,
PI - Star Lord
