INN3694C-H4606, Not able to get current more than 0.2 Amp at 5V.
Posted by: mukul09jain@gm… on
Hello members,
Can you help me with the below issue?
I have designed a 5V, 3A as dc power supply by using INN3694C-H4606. I am using this for GSM module and battery charger circuit of 5V, 3A. It is not providing current more than 0.2A at 5V. Please let me know your suggest check points.
Submitted by PI-Enderman on 04/11/2022
Greetings mukul09jain,
We are going to need more information in order to help you on your issue.
What transformer did you use and what is the winding configuration (primary and secondary turns, thickness of wires, etc.)? I would be of great help if you provide the PI-Expert or PI-Xls as well as the Schematic Diagram of your design.
We are looking forward to hearing back from you.
PI-enderman
