how to design output current using lnk304
Posted by: minikhh
hi i'm using lnk304 and make output voltage 5V
thank to application note an-37 and 1.44W, 12V, 120mAbuck converter reference circuit in linkswitch-tn family datasheet,
i understand designing voltage which i want.
but I'm not sure how i desing output current like 5V 50mA, 5V 100mA, 5V 150mA
May I get some know-how design output current?
Hi minikhh,
You can use this PI online tool in designing your project.
https://piexpertonline.power.com/
Jedidiah.
Thanks, Jedidiah - that's a little more explicit...
With a buck converter, the sum of output current plus the current ripple on the inductor must be less the the self-protection current limit of the Linkswitch device in question. If you use the design software for the Linkswitch-TN, you will be guided to a device that is appropriate for your desired output current. The software can be downloaded at power.com or used online.
