How to convert DC to AC
Posted by: ROSELJR on
For example, 24V direct current is converted into 220V alternating current, how much alternating current is needed to convert 1-degree point?
Submitted by PI-Enderman on 03/24/2022
Greetings,
Thanks for your inquiry.
The process of converting DC to AC is called "inversion". As such, devices/circuits that perform such functions are called inverters. A simple way of inverting DC to AC is with the use of 4 switches in a full bridge configuration (see Attached). The alternate switching of the switches impresses an AC voltage on the load.
Unfortunately, we do not have products that support low voltage DC to high voltage mains AC applications.
If you are interested in other inverter applications such as motor drivers you may take a look at our BridgeSwitch line of products.
Have a great day.
PI-enderman
