EMI problem with InnoSwitch3-EP
Posted by: IKastantin on
back to my project. I have already built my 50W power supply using INN3679C-H606. I have a problem with conducted emission test.
I have peak @ 700kHz. Peak level is ok but the average is very close to the limit.
Do you have any idea about solving this problem?
please find attached the schematic.
Thanks & BR,
Imad Kastantin
Submitted by PI-Wrench on 03/09/2022
I would suggest trying to modify the snubber across your synchronous rectifier fet. R109 is too large and C106 is too small. For a starting suggestion, try 10 ohms for R109 and 470p for C106. You would balance between damping ringing at that location without incurring excessive power dissipation in the snubber. It would be a good idea to monitor the voltage across the sync fet during operation to get an idea of the amount of spurious voltage overshoot and ringing.
